MOD54415 iprintf() for float type problem
Arturino
Post by Arturino »
I'm having problems with float numbers output on NB54415.
Command:
iprintf("Val %4.2f \r\n", 3.132543);
returns
Val    f
Is output of numbers with floating point implemented in the library?
How I suppose to output them?
tony
Re: MOD54415 iprintf() for float type problem
Post by tony »
You need to use printf. iprintf only handles integers.
Arturino
Post by Arturino »
Thanks, it worked.
The 'i' in iprintf() = integer. Adding floating point takes up a lot of space for those application that are space limited.
same goes for the sprintf(() / siprintf functions and the preferred snprintf() / sniprintf variants
