insufficient ram
Posted: Fri Jan 25, 2013 8:25 am
by tsc
How do I resolve insufficient ram problem ?
Thanks.
Re: insufficient ram
Posted: Fri Jan 25, 2013 9:39 am
Use less ram :)
You are out of memory. Without details of what your device is doing (and what type it is, though I'm assuming an L2E...) I can't be much more specific. You could see about putting any data stuff that doesn't change into flash/rom by declaring the variables 'const'. That is one of the major drawbacks to the L2E; it's an extremely memory limited part. You can also make sure you're stripping out all features you don't need. If it doesn't need a webserver, make sure you're not running the webserver, etc.
Posted: Fri Jan 25, 2013 9:46 am
by tsc
I wrote a big file into Netburner board (don't know the exact size). I just want to recover my Netburner to be able to reload any new software.
I don't care about the files on the board. Is there a way to tell what's on the board so I can delet that file. Or do a hard reset to go back to original fresh state ?
Posted: Fri Jan 25, 2013 9:59 am
Which netburner board?
Are you seeing the out of ram message when you compile or when you try to update?
We need a tiny bit more info to be able to help you...
Posted: Fri Jan 25, 2013 10:23 am
by tsc
I was trying to upload new software to the Mod5270 board.
Posted: Fri Jan 25, 2013 10:50 am
Then try the serial update procedure outlined in section 4.32 of the getting started guide....
(In nburn\docs\documentaionOVerview.pdf)
Posted: Fri Jan 25, 2013 11:16 am
by tsc
Sorry can't find the link
Posted: Fri Jan 25, 2013 12:15 pm
by tsc
The serial update did not work. Just want to delet that file. Anyway to access the board ????
Posted: Fri Jan 25, 2013 1:14 pm
The only way to replace the app on the board if autoudate does not work is via serial download...
here is a link to a different serial download document...
http://wiki.embeddedethernet.com/Suppor ... via_Serial
If that can't be made to work you need to RMA the board...
Posted: Fri Jan 25, 2013 2:52 pm
by tsc
I tried several different files via serial download, it seems to fix the problem.
Thank you all for the help.
