Page 1 of 2
Stopwatch.h for MOD54415?
Posted: Fri Aug 24, 2012 1:26 pm
by barttech
I have the Stopwatch code from lgitlitz but it needs a
NB_CPU_CLK
value defined.
#if (defined MCF5282 || defined MCF5213)
#define NB_CPU_CLK ( 66355200 )
#elif defined MCF5272
#define NB_CPU_CLK (62500000 / 4096)
#elif defined MCF5208
#define NB_CPU_CLK ( 83335000 )
#elif defined MCF53017
#define NB_CPU_CLK ( 80000000 )
#elif (defined MCF5234 || defined MCF5270)
#define NB_CPU_CLK ( 73728000 )
#else
#error PROCESSOR NOT DEFINED
#endif
What is the right value for the MOD54415?
Re: Stopwatch.h for MOD54415?
Posted: Fri Aug 24, 2012 3:53 pm
In the latest code release there is a hirestimer.cpp in the MOD5441X directory...
Try using that...
Posted: Sat Aug 25, 2012 6:41 am
by barttech
Thanks Paul,
Is there any documentation for this and other new functions beyond the comments in the code?
Or examples?
Like, in void HiResTimer::delay(double delayTime), is delayTime in msec or usec or something else?
Do I have to call start() before using delay()?
The .h file says
"Starts the selected timer. The user MUST call HiResTimerInit for the given timer before calling this method."
but I cannot find HiResTimerInit, does it mean HiResTimer.init() ?
What does the parameter InterruptTime mean for init()?
etc.
Sam
Posted: Sat Aug 25, 2012 8:48 am
by barttech
If I try:
#include <HiResTimer.h>
HiResTimer MOD54415Timer(1);
MOD54415Timer.init();
I get errors that the constructor and destructor are private.
Sam
Posted: Sat Aug 25, 2012 9:20 am
In cpp a constructor is called when you create the object, and the destructor is called when the object goes out of scope. So you don't call those directly. I don't have the code to look at, but maybe that info will help a bit.
Posted: Sat Aug 25, 2012 9:38 am
by barttech
Right, but usually there is a public constructor, HiResTimer's are private. I'm guessing that one of the other methods also constructs but I can't see what or how.
Sam
Posted: Sat Aug 25, 2012 1:22 pm
by greengene
did you look at the example in /nburn/examples/utils/HiResTimerDemo?
Posted: Sat Aug 25, 2012 2:11 pm
by barttech
Nope, I missed that one, thanks!
It looks like it will answer my questions.
Sam
Posted: Mon Aug 27, 2012 2:44 pm
As the developer responsible for the port from Larry's original StopWatch library, I'll try to clarify a couple things.
First of all, my apologies for the typo in the header file when referring to HighResTimer.init(). There is a full set of documentation in the Runtime Library document, in section 22.
As for the issue with the constructor, this was a deliberate design choice. The HighResTimer acts as a user friendly interface onto the processor's DMA timers. With this in mind, it should be obvious that there is a finite supply of potential HighResTimers. Therefore, the class is designed to enforce safe utilization of the resources and deny unrestricted access to instantiation of timers. If you are familiar with design patterns, you will note that this is a Singleton class, with multiple instances.
Posted: Tue Aug 28, 2012 12:47 pm
by barttech
Thanks Dan,
Somehow I thought the HiRes timer was newly implemented for the MOD54415, so I didn't look in the Runtime Libraries docs. My bad.
Sam
