Unit Testing
crypt
Unit Testing
Post by crypt »
I'm currently setting up some unit tests for our NetBurner code using a Java based connection. I have this piece of code, that I'd like to test a failure on.
int read_amount = read(fd_Network, network_buffer, FD_BUFFER_SIZE-1);
writeall(fd_Serial, network_buffer, read_amount);
iosys.h says that the read() function will return a negative number on failure.
Is there an easy way of creating a failure with read()?
edit: took away statement about maybe causing an error in writeall() after looking at code.
Re: Unit Testing
I'm not just trying to be pedantic but what you are proposing is not a unit test, it is more of an integration test. If you are trying to satisfy a unit testing coverage requirement you will probably need to insert a testing seam into the code. If you don't care about the distinction, then one way to force read to fail would be to use an invalid file descriptor for fd_Network. The error returned should be TCP_ERR_NOSUCH_SOCKET which is -4.
Without capturing the return value of writeall() it might be tough to write a good test.
