I was trying to change the IP address of a MOD5282 on a MOD DEV 100 V1.12 board using the IPSetup utility. I blanked out the IP and Mask fields and then pressed the Set button. The MOD5282 disappeared from the "Select a Unit" window and would not respond to MTTTY on the USB connection either. Not even after reset or power down. I connected it to a serial port and all I get is a repeat of
- Trap occured
Vector=05FMT =00 SR =2700 FS =00
Faulted PC = FFC004EC
D0:00000000 003F4800 00000018 00000000 00002700 10924F50 91C61551 13B010DF
A0:FFFFAAAA FFC04094 20000464 FFC00274 FFC00512 FFC00FCA 200007FC 20000640
Is there any way to get this back?
Ed
