Re: MOD5213 iprintf() error for UL and ULL types?
Posted: Fri Apr 17, 2020 2:09 pm
For a variety of reasons, I can't check in the fix right now....
My personal Git state is in the middle of a differnt project...
go to nburn\nbrtos\source\nbprintf.cpp
About 571 lines after the copyright (our git repo and the code I work on has a place holder for copy right)
You will find a switch statement that looks like:
switch (f)
case 'f': ret = OutputFFloat(pf, data, d, pfs); break;
case 'e':
case 'E': ret = OutputEFloat(pf, data, d, pfs, f); break;
case 'g': ret = OutputgFloat(pf, data, d, pfs, gc);
Add another case to it so it looks like:
switch (f)
case 'e':
case 'G': ret = OutputgFloat(pf, data, d, pfs, gc); break;
By the way if your using 'G' and the exponential version would be shorter ... that works with the correct E/e for G/g as is
its just that when it determines that the f format would be shorter it fails...
switch (f)
case 'e':
switch (f)
case 'e':
