Re: Sharing data between modules: switch req'd or other ways?
Posted: Tue May 26, 2009 12:41 pm
The easiest way to do multi-point PCB level connection would probably be with I2C and the I2Cmulti driver. The RTC plus at least 10 other devices (including the NBs) will all be able to be on the same 2 wire bus with no extra hardware. The driver will allow you to give each device its own address and any collisions should be handled by the driver. The only problem is that this interface is not too fast... default it is about 100Kbit and you can increase the speed to about 300-400Kbit depending on the capacitance load on the bus.
Ethernet with a simple off the shelf switch will be a quick solution plus the transfer speeds will be in the 50+mbit range if you are using UDP.
You can use a FPGA to share data on the processor bus. A dual port SRAM chip might even be a better solution since the hardware is already done for you. This will probably yield the highest bandwidth but requires external hardware at the PCB level.
If you can free up one of the 3 UARTs then you can get pretty high bandwidth by using synchronous serial. This is another interface that would require no external hardware, just 3 wires (rx,tx,clk). In my testing of this I was easily able to get 10+mbit transfers between modules. This method will also use one of the DMA timer inputs for the UART clk input. You probably will need to use a DMA timer output on one of the modules to generate the clock for all of the UARTS.
I would stay away from the QSPI if you are using the SD Card interface. Sharing this bus can be tricky. There is also no slave interface for this bus so you will need external hardware such as an FPGA or FIFO to convert the master to a slave. If you are going to do the external hardware you should probably go the processor bus route which will be faster and easier to code on the software end.
-Larry
-Larry
