select() with timeout on stdin not working
dnishimura
Post by dnishimura »
int readfds;
fd_set fds;
int stdin_fileno = fileno(stdin);
FD_ZERO(&fds);
FD_SET(stdin_fileno, &fds);
iprintf("Press any key to enter configuration.\r\n");
readfds = select(stdin_fileno + 1, &fds, NULL, NULL, TICKS_PER_SECOND * 5);
iprintf("STDIN: %d, READ_FDS: %d, FD_ISSET: %d\r\n", stdin_fileno, readfds, FD_ISSET(stdin_fileno, &fds));
Above prints out "STDIN: 0, READ_FDS: 0, FD_ISSET: 0", so it appears select() doesn't work on stdin. However, fgets works fine on stdin:
fgets(buf, sizeof(buf), stdin);
Am I missing something?
Re: select() with timeout on stdin not working
As a test I would try closing stdin, then re-opening with OpenSerial() (going from memory on the function name), getting the returned file descriptor, and then using that fd in your select function.
Unless you change it stdio opens in polled mode.
(This is a very old choice I wish I could undo)
To fix this and have it work the way you want ...
#include <iosys.h>
then
void IrqStdio();
