I have the following code for IRQ
#include "predef.h"
#include <string.h>
#include <autoupdate.h>
#include <dhcpclient.h>
#include <networkdebug.h>
#include <pins.h>
#include <pin_irq.h>
#include <smarttrap.h>
extern "C"
void UserMain( void *pd );
void EdgeportISR()
J2[15]=J2[15]^J2[15];
void UserMain( void* pd )
/////Usual Routine
OSChangePrio( MAIN_PRIO );
//EnableTaskMonitor();
EnableSmartTraps();
J2[15].function(0);
int i=J2[15];
J2[15]=0;
SetPinIrq( 47, -1, &EdgeportISR);
while(1)
Where can I find lua.a file? Thank you**** Build of configuration Release for project readppm ****
m68k-elf-g++ -O2 -falign-functions=4 -IC:\nburn/include -IC:\nburn/MOD5441X/include -IC:\nburn/gcc-m68k/m68k-elf/include -IC:\Users\AvionicsIRL\Desktop\Electronics\MOD54415\NetburnerCodes\readppm -gdwarf-2 -Wall -Wno-write-strings -c -fmessage-length=0 -fno-rtti -fno-exceptions -mcpu=5206e -DMOD5441X -DMCF5441X -o readppm.o ..\readppm.cpp
..\readppm.cpp: In function 'void UserMain(void*)':
..\readppm.cpp:49: warning: unused variable 'i'
m68k-elf-g++ readppm.o -Wl,-Map=readppm.map -mcpu=5206e -Wl -Wl,-n -TC:\nburn/MOD5441X/lib/MOD5441X.ld -Wl,-RC:\nburn/MOD5441X/lib/sys.ld -Wl,--start-group,C:\nburn/lib/MOD5441X.a C:\nburn/lib/NetBurner.a C:\nburn/lib/FatFile.a C:\nburn\lib\debugLibrary.a C:\nburn\lib\lua.a -Wl,--end-group -oreadppm.elf
m68k-elf-g++: C:\nburn\lib\lua.a: No such file or directory
Time consumed: 395 ms.
Regards,
TM
