In the examples that come with Netburenr, there are only two examples for the Nano54415, one called MinimalAppp, and a second called EFFS-STD-HTTP. For this later example. if I import the fileSystem from the example into an empty project, I get 84 errors. The instructions at the top of main.cpp indicate that before the program can compile, I need to remove the compiler link to FatFile.a and add a compiler link to \lib\StdFFile.a. However, this last file does not exist. The only files in the \lib directory are DBdebugLibrary.a, DBNANO54415.a, DBNetBurner.a, debugLibrary.a, fatFilea, LFNFatFile.a, NANO54415.a, NetBurner.a, SFNFatFile.a.
If I do a file search in the Netburner master directory it does not find this file.
Can anyone let me know where this file could be found?
Regards
Lachlan
Missing Files in NANO24415 Example
Re: Missing Files in NANO24415 Example
Can you please tell me what build number you have? You seem to be having a fair bit of trouble with files.
Actually, you probably want to create a support ticket with us so we can go through more in depth.
I would get the latest release. There are a lot more examples in mine, and some specific to the file system. The Stdffile.a is in my \nburn\lib directory.
