Lowest ADC volatge that can be read using MOD5213
nicobari
Post by nicobari »
I would like to know whats the minimum physical voltage that can be fed into ADC pins of the netburner. I am hoping to read signal of range 0.3-24 mv without amplification to reduce complexity. Thank you in advance.
Chris Ruff
Re: Lowest ADC volatge that can be read using MOD5213
Post by Chris Ruff »
12 bit ADC -
3.3 volt / 4096 = 0.0008 volt per step
you will get some 30 digits out of a potential 4096 digits with your stated range of 0.3->24 mv
and the first digit doesn't turn on until .8 mv arrives
doesn't look too promising. And the noise on a 12 bit AD will kill you unless you filter the signal- hope you don't need to go too fast.
I would amplify it and filter as much as allowable for your application
